Can i buy Basestations without controllers?
Did order the 8k-x and was woundering if i can buy Basestations also? Tried asking suport but got a strange answer.
You can buy the Valve basestations directly from Valve (Steam)
Shortly after the kickstarter ended the arrangement between Valve and Pimax changed, Pimax could no-longer sell basestations outside of a bundle. If you have a look around you kind find large volumes of version 1 lighthouses being marketed cheaply, both are compatible with the Pimax headset (not peripherals).
I bought from Valve and in 4 days I had one at home.
What is the strange answer ?
