So I was on Amazon today and this item popped up. It says it works for Valve Index, Rift S, and Cosmos confirmed, and from the specs it should work for the pimax headsets… If anyone wants to try it, by all means it’s available via Amazon Prime with free returns and costs $50.00
DP 1.4 extension with signal booster, and USB - 5meter extension
I just got this cable https://www.amazon.com/gp/product/B088ZB3146/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&th=1 and its a little different but is does say it works with the same HMD but i can only get it to detect the 8k plus with new 4.5m 2 usb 1 display port cable. if i go connect it to my pc first then the extension cable. I think there maybe a software bug making it not work.
