Guys found a fix for stutter in DCS.
wirhin your DCS folder path is DCS World OpenBeta/ distr/ Directx / DXSETUP.exe
try it ive been suffering for months and months trying allsorts to remove stutters
S
S
i will have to try that but what did you do just run the exe ?
Hmm updating the DirectX? That sounds odd, but definitely worth a try!
I have found in the past often best to run the Dx installer that shipped with the game as it may have a patch that is not installed even if your dx is up to date. Either way never hurts.
It’s a practise I have used since xp days.
Not so much updating as installing as it wasnt there to begin with. its sorted out our collective DCS issues (stutter) 1 Pimax 1 HP Reverb 1 Vive 1 Other?
s
Yes it loaded like i never had DX11 installed
s
