Because the DMAS takes so long,can we get the KDMAS instead for those who ordered the DMAS?
who else like to change?
Im not sure I even ordered the dmas. What does your order look like on the backer store if you are getting a dmas?
I ordered the DMAS. I’m going to stick with it because it’s my understanding that the sound quality and it is much superior to that of the KDMAS.
I would advise against doing that even if they were to let you do it. The KDMAS is supposed to be inferior to the DMAS by quite a margin. Pimax is always slow to deliver on things but I do believe it will come eventually
