What resolutions do you have set your monitor to in Dirt? I have not touched it so it should be at 3440 × 1440.
In PC2 my Menus in VR Scale with the set desktop 2d Resolution in VR - since dirt also switches to VR at the start of the race, maybe that can used?
Only thin that is unreadable is the Button/ Action text in the Menues and the times displayed during racing
Ah, interesting point. I have a 4K monitor (3840x2160). The text is small, but readable on my monitor. I wonder if DR2 is using the monitor text size in VR. (I thought it might be due to the wide FOV of my 8K.)
I’ll test it, when I get a chance.
Yes, my experience is the same. In dirt and Dirt 2. From normal to large feels like you play on 22" monitor and then on 32". I could lower my all settings to have good frames on large fov. But lowering graphics settings the gpu usage gets lower, instead of giving me 90+ fps.
True. I use a 1080ti so FFR not being an option at present means for me I either settle with 72Hz, no smart smoothing and turn off AO and ground cover completely which looks very bland, or I can keep these things and use 90Hz with smart smoothing. Luckily DR2.0 plays well with smart smoothing at 90Hz refresh rate as long as the CPU & GPU both have some breathing room and artifacts are kept very minimal (wipers and tops of mirrors being about it). I think I’d tend to go with 72hz and no smart smoothing like yourself if i had an RTX card capable of FFR and a few more frames; in OG DR I use 72hz fixed and no SS but I can get away with it as the graphics are a little less taxing.
Sharing this info:
As you all know, VR support for DiRT Rally 2.0 was added in Version 1.7, however we’re fully aware that some are enjoying it less than others due to technical performance. You’ve given us feedback, and we’ve been having many discussions internally about how to ensure you all have the best VR experience possible with our game.
First up, we posted a VR settings guide. If you haven’t seen it yet it’s here:
Next, we looked at what changes could be made in time for our next update. Version 1.8 is expected to release around September 3. Here’s a snippet of the Patch Notes (which we’re currently assembling) detailing what’s changing for VR:
Added option allowing players to choose whether to launch the game in 2D Mode or VR Mode.
Added support for separate graphics presets between 2D Mode and VR Mode.
Added support for “-novr” launch command.
Added ability to bind “Reset View” to a preferred buttons/keys.
Resolved issue where game would crash if no VR headset was plugged in.
Improved readability of UI text in VR Mode.
In addition to this, we are currently investigating what is required in terms of time and resources to implement Oculus SDK support into the Steam version of the game.
Adding Oculus SDK support to the Steam version is not a simple matter of flicking a switch, nor is it a case of copy/pasting code from the Oculus version. It’s also not something that can happen immediately or in a very short space of time. We’ll share more in the future once things progress.
Thanks for the info! These 4 are really needed. I wonder if the crash fix will also prevent the crash at startup when running fpsVR? The poor UI text is what’s currently preventing me from enjoying the game.
I just got permanent bug - FFR is not working anymore even after reboot. It works in my system in DR2 before.
I haven’t got any problems with the ui and my pimax 5k+.
My monitor is a 2k one and use en pitool ss 1.0
It might be sizing the UI text according to your monitor res. Mine is 4K. I haven’t yet tested with a lower res.
Guys 1.8 is live , pls consider update
I would, but my friend asked his lightstations and controllers back so i have to wait for pimax’s lightstations and controllers hahaha ( i hope this year… )
so far its not working at all with Pimax after update ! game run only at monitor screen, any idea ?
Edit : Works now. They prepared separated hardware settings.xml for VR .
Anyone manage to get decent performance in this yet?
Just to share experience for lower end users:
I’m playing it with a Pimax 4k
on a stock 3570k and a very old AMD 7950 3 GB (r9 280) overclocked.
That means well below the recommended requirements so I went with the “low” graphics preset and AA disabled. I haven’t tried anything else.
I have roughly the same graphical experience as Dirt Rally 1, and it runs very well and extremely fluid.
ALL text/UI is completely unreadable in 3D VR because all text/ui is way too small. I’m using a 1920x1080 main monitor.
text on the projected 2D screen is barely readable.
But this is just clearly the fault of Dirt Rally developers.
None of it matters as I’m just there to race with all UI disabled anyways.
TLDR: Dirt Rally 2 works great even with low end hardware.
I have played a lot of Dirt 2 in Aug-Okt. I also find it great - my most played VR Game at the Moment (until the base stations arrive….)
Yeah. They patched it up. It works a lot better for me now.
Did you read the optimizations thread ? In my case it did give me a better experience then before ( also after the patch I mean.)
@Yen posted a guide here
https://community.openmr.ai/t/ultimate-guide-to-tune-up-pimax-5k-8k-no-more-eye-strain-glare-and-distortions/22836
Yeah, cheers I did.
I’ve got it quite heavily tweaked.
im currently playing dirt 2.0 with my pimax 5k+, the resolution it runs at is incredibly low by default. i increased steamvr ss to 150% for now but its still not where i would want it. and for some reason the menues and loadscreens etc. seem to still run at the old resolution which i have to guess is 480p or something rediculous like that.
graphics seem fine otherwise, as far as i can tell its just realy low res for some reason… i guess it was targeted at the old 720p hmds?
Mine sometimes gets stuck at really low res when I change a setting. The fix is to toggle the AA setting. It forces it to refresh back to normal.
