Some way to automatically start steamvr home, when you start the hmd?
There is a checkbox for it in the SteamVR settings, general section. It’s the first item, called “Use SteamVR Home”.
I think he means to start SteamVR when You power on the HMD by the power button.
I don’t know how to do that but Pimax Devs probably do. They could make it another option in PiTool.
BTW, SteamVR will start of You turn on Your controller (it’s a SteamVR config file option and I’m pretty sure it’s default). At least it happens for be with the Vive Wands. You could try that instead.
Thanks you! I recently got some knuckles and didn’t know this trick, just press the power button of one of them once, and it will take you to steam home, thanks.
Even so, I think it would be good if pimax added an option in pitool to have steamvr as home by default.
