Assetto corsa + reshade
In I wanted to use the Assetto corsa reshade 3.0.6, but failed on the monitor reshade works and no helmet. In assetto corsa reshade helmet to use?
Unfortunately, SweetFX/Reshade does not work with VR Direct Mode/Non-Cinema Mode, curently.
This is bad. Using a reshade you can get a good image.
Indeed, Assetto Corsa use to work in Extended Mode which supports injectors but after the updates, eventually, this has been superseded in favor of strictly Direct Mode.
If using Piplayv1.2.5x beta Try Video Mode. It is extend mode.
Meant Assetto Corsa has moved to Direct Mode.
