As of today, the sound in the Pimax 8KX with DMAS is very quiet. I don’t see the problem.
I looked at everything in Windows 11. It’s only quiet in the 8KX, like it’s only 30% the volume. I’ve already tested the old Pimax cable and it doesn’t work either. Current Pitool version, also beta tested. always the same, the sound is quiet.
There is a problem with the Pimax audio drivers… it must be set to 7.1 but it doesn’t mixdown properly to 2 channels and windows does a horrible job doing it manually through settings. I found this work around… Pimax should just put out a Firmware fixing this issue as it is completely driver related and probably an EASY fix, why they don’t do it is beyond me. https://www.reddit.com/r/Pimax/comments/x0c1an/comment/inqz4nu/?utm_source=share&utm_medium=web2x&context=3
