Artisan vs 5K+/8K+ Buying Question
Thank you very much @Heliosurge, thats really helpfull :+1: I was already wondering why the MAS wouldn’t fit the Artisan. Will definitely have a look at the Guidebank as well as looking for posts from @Ludiks.
Actually my Artisan (used) came with the bare cheap strap but with the face comfort kit.
Your welcome!
There is an install guide I believe posted there. You need to remove the face gasket and then the hinges to put the MAS on. Then reattach the face gasket.
:beers::sunglasses::+1::sparkles:
Okay seem to be missing that one.
