Apology for the delays with Kickstarter campaign
Good eye but still doesn’t explain why they didn’t receive so many surveys especially when most everyone seem to have filled it out the first time. Either a massive fuck up or they did it on purpose so they could say look backers with high numbers are receiving headsets.
I think @Matthew.Xu or @anon74848233 will answer soon
I hope they will answer soon.
i have filled in survey 4 times and it still say, need backer to reply.
@Matthew.Xu @anon74848233
Yeah, I’ve filled the survey two times, but the spreadsheet says Need backers to reply the survey… :broken_heart:
Ok, ima fill it again,
6378 here @anon74848233
The link I received was a unique, one time survey. Not sure if this is the case for other backers, but mine says I’ve already taken the survey when I click the link again.
@JonGraham
your backer number is 1381,status is “finish production and will arrive SH by 1/7”
Try the button further down the email , I just did it again using that button as opposed to the link , Survey is monkey business
What “finished production and will arrive SH by 1/18" means? It says that to my backer number 3234. Actually what does “SH” means?
Shanghai !!! 20202020
Hold up…so means first will arrive Shanghai and i will recieve a tracking number then before arriving to my country Romania? :open_mouth:
Thought they were in Shanghai?
Exactly my thought…
Interesting, just filled out the second survey.
This will be the 4th time I’ve filled out surveys with the same information now…
OMG - this is a fiasco…
The first link wouldn’t let me complete it again, the second link in the email did. Have completed it yet again.
Backer 3258 here. Filled out the survey 2 times and the spreadsheet still says “need backer to reply”. I also contacted Pimax support via email yesterday, but no answer so far :confused:
edit: completed for the third time now. @Sean.Huang
Same boat for me as well. Filled in several surveys but says on spreadsheet not completed. I want to believe this is just an error and the spreadsheet not updated yet. Patience…
Thks, i just tried that, we’ll see…
I just filled it out again using the button at the bottom of the email. Maybe this is the problem. You have to use the begin survey button at the end of the email and not the link in middle of the email.
@Tyleristall
Guess the column name should be clear enough actually.
@Sean.Huang What “finished production and will arrive SH by 1/18" means? It says that to my backer number 3234. Actually what does “SH” means? Is that Shangai or what? I thought they were already there…
