As far as i know we need the support of DSC for native 4k.
The vive link box does have a mini dp-in and HDMI-out, maybe using an DSC compatible converter chip inside?
Please Pimax, could you try?
I do not have an DP2mini-dp-cable lying around and i think you do need a special piplay version to support that, right?
I looked at fixit for the chip in the link box, but they did not open it.
Just to clarify:
If we find a DSC compatible chip in a DP-to-HDMI konverter box, we can run the 4k in native VR?
Sure, or just in theory?
Anyone @Pimax-Support tried that?
Does then the scaler turn itself off?
Can the slim cable of the 4k handle the 4k signal?
It should be a trivial task to find a compatible cheap dp-to-hdmi adapter. I am curious why we still can not use 4k on the 4k. Do not get me wrong, i do not really need this feature. But it would be nice to have, if doable without a lot of hassle…
