Xplane 11 works fine with steam vr but xplane 12 hasn’t. The only difference I see is that I bought xplane 12 directly from laminar research and xplane 11 thru steam. Even if I run xplane 12 thru steam it crashes upon loading a plane. Any luck anyone?
How are you launching Xplane 12? from pitool or it’s exe? You can import the launcher exe into steam or pitool but I don’t have xplane so maybe someone else could elaborate on the best method.
I have launched from steam and the exe. same result. I can get the VR to show the main settings and flight configuration menus, but once I load a plane it crashes.
What version of steam vr is installed?
