Hi,
I have read on this forum about some test with a android tv-box and the pimax.
But i can not found any details about this.
Do have someone more information about this? I like to test with it…
Regards,
Alan
Hi,
Regards,
Alan
Truth there is ni direct support for Android. There is info on folks getting a raspberry pi working that might help with Android. I am sure though you will likely need to root your android box if it can be done.
@Sjef might have advice or info on if possible.
Thanks for the info!
The android tv box has been rooted, so every script and adb commands can be run.
I can put the droid box in a lot of HDMI modes, but what kind of mode must the Pimax set on?
I can use commands like: adb shell wm density 240 or adb shell wm size 1920x1080
But the most imported thing is how to activate the HDMI port with the PiMax.
Maybe A hdmi splitter With the first device a basic hdmi monitor and with the pimax as slave?
This Raspberry pi project might have info that may help.
