Hi all after pondering about it for a long while i got to a point where this crazy idea might or might not be feasible… as we all know both Nvidia and AMD dropped the support for multiple cards and for good reasons… yet Nvidia released something called VRWorks which has VRSli…
Now my crazy idea would be to use 2 cards separately, and each card run its own monitor…
this by have a cable with 2 HDMI connectors or similar from the pc to one single cable to the headset… theoretically if implemented right this will allow players to save money on hardware as the only thing needed between the 2 cards is just timing… while SLI/CF actually had to send information from one card to the other and thus a huge bottleneck not to mention the scaling issue…
this is not only a way to bypass the many issues of multiple GPU setups. but it also ensures to run each monitor in the headset @ max fps without having the 2 monitors fighting for a single card.
Although its just a crazy idea i want to know what people thinks about it and if someone has suggested this already
Cheers Dave
