Date:9/6/2020 Issue Title:AMD Driver Support Description:Pitool reports that the latest drivers from AMD are too old. This had been occuring since AMD released driver 20.5
HMD Model: 5K+ First 3 Numbers Serial: 204 Pitool Version: 263 and 2.071 HMD Firmware:264 Tracking:Lighthouse
Try 1.0.1.254_alpha . If that fails, try .197 and .144 . These are PiTool versions I have been able to certify perform well with the most intense use cases. I probably tested at least the oldest of these with AMD CPU and GPU.
However, Navi_8k has the right idea. Unfortunately, Intel/NVIDIA has too much of an edge, and VR can make smooth use of every few extra % on a single CPU thread and single GPU. To the point buying top-end binned hardware and overclocking is well worthwhile.
I have a ThreadRipper 1950X and AMD FX 8350 myself, and tried a Ryzen 2700X before going 5.1GHz i9-9900k and 2045MHz RTX 2080 Ti. Wouldn’t use any of the AMD stuff for VR right now.
You are also missing out on Smart Smoothing and foveated rendering with AMD GPU.
Ah ok. TBH, I am going to have to disagree with that desire. Aside from the PiTool team having enough trouble just avoiding regressions, until AMD supports the very basic stuff we need for VR, AMD users should get some kind of warning.
Both of which are hit and miss with many titles in VR.
Anyway, it is good to have both vendors supported and maybe just a one off warning for AMD users on installing PiTool that Smart Smoothing and Foreated Rendering are not supported.
