Aircar problems
Wondering if anyone can help with a couple of problems.
  1. Aircar cannot be loaded from PiTool My Games, so I can’t use a custom profile for it (or is there another way?). Is there anything I can do to fix it, or is it one for the Pimax team?
  2. Inconsistent crash problem on startup - it routinely crashes, but not always. Tonight I have had no luck and had to give up, last night I had a few crashes but it did eventually work. Not sure what solved it though. Previous evenings no problem.
One change is that I switched to large FOV last night, which works great at 90FPS, when it loads.
D3D texture crash error - I assume it is something to do with switching PiTool config, but by turn, restarting SteamVR / rebooting headset / restart service doesn’t fix.
Hell, I even rebooted the machine just in case, which is not a solution to me (ie relevant app or service restart is sufficient), but still no joy.
I haven’t given up and reverted to Normal yet, as Large can work. It’s possible Normal might still crash anyway. Any suggestions appreciated, thanks.
LowLevelFatalError [File:Unknown] [Line: 819]
Rendering thread exception:
LowLevelFatalError [File:Unknown] [Line: 328]
Direct3DDevice->CreateTexture2D(TextureDesc,SubResourceData,OutTexture2D) failed
at D:\Build++UE4\Sync\Engine\Source\Runtime\Windows\D3D11RHI\Private\D3D11Texture.cpp:481
with error E_INVALIDARG,
Size=17068x5268x1 Format=DXGI_FORMAT_R32G8X24_TYPELESS(0x00000013), NumMips=1, Flags=D3D11_BIND_DEPTH_STENCIL D3D11_BIND_SHADER_RESOURCE , Usage:0x0, CPUFlags:0x0, MiscFlags:0x0, SampleCount:0x1, SampleQuality:0x0, SubresPtr:0x0000000000000000, SubresPitch:0, SubresSlicePitch:0
Try less supersampling & or reduce pitool render. Don’t have title is it Oculus? If so one youtuber reccommended pi render at 0.5 to 0.75 & use Oculus home tweaks & in game settings.
Sure thanks let me check, it should have been running on PiTool 1.0 and no SS but res isn’t right, and I did manually edit my SteamVR config a while back.
Not an Oculus title AFAIK, I’m using the free Steam version. Impressively immersive for its simplicity and unmissable for anyone who likes Blade Runner :+1:
Any idea what to do if an app won’t launch from PiTool?
I usually launch titles like that from steam. Just change pitool global settings to suit
OK thanks yeah that’s what I’ve been doing. I wasn’t sure if I could fix it myself by manually editing a config somwhere (not spotted an option yet), or if only Pimax can fix it.
Yes we could use an external tool to edit the unfounded.
When home again will need to find some time to dive again.
@park though may have some great input on this.
I did a search through the Pimax install folder and checked out any .cfg, .config, .json, .settings, .xml files but didn’t spot anything for the custom app settings…
I can launch this game, but I see no car or anything, just floating above the city. Controller buttons do not work.
SteamVR shows error: “Failed to load input bindings for “AirCar…”. Please Select another binding option.”
But no matter what I select in SteamVR, such as ZKNIGHTS7 binding, there is no controls available. Beautiful city, tough.
The intro does that until it picks up a controller button press. On the Index controllers, most of the buttons work by default so I got past that screen, but turbo did not. I had to choose another profile to fix that. It seems that defaults have problems.
You haven’t mentioned which controllers you have, not sure why you wouldn’t be able to select a compatible profile for your controllers, sorry.
I have Vive controllers. I did choose ZKNIGHTS7 binding, as it seems to be the only one in there, but it does nothing.
There’s not many controls, see if you can create a custom one yourself?
Dev mentions a wand binding here but maybe it’s been deleted or changed: https://steamcommunity.com/app/1073390/discussions/0/1643170903490242441/
