Any idea how to access this as I have no clue. Thanks in advance.
Do you have fpsVR, its free on Steam and I could be wrong but I think you can control it from there. fpsVR is an app that allows you to see your fps and other PC functions inside your VR headset while in game play.
Thanks. Can I also adjust settings via this app?
I was told that you could but I havnt tried it yet. I would recommend it even if it doesnt. It lets you see how your SS and Pitool rendering setting are affecting your fps in real time.
You want OpenVR Advanced Settings.
Ok. Thank you very much.
Many thanks Brian. That makes sense now.
Brian, do I need controllers in order to use this particular patch?
