Hi, would anyone know the AC power adapter specs for the Pimax 8K? I’m traveling and forgot to pack the power adapter so I’m hoping to find out the specs and shop for a compatible one locally (in Australia).
Info greatly appreciated. @Pimax-Support, @SweViver
12V, 2A
Thanks Trevor.
Should be easy enough to hunt down a replacement.
Right, got a 12v 2.5Amp adapter locally with swap able plug ends.
The outer diameter of the plug as recommended by Pimax is 3.5mm
All good and back up and running. Whew.
