Hello, I’m a little confused. I read a thread by a Pimax rep that said the latest beta release shouldn’t have been released. Do I want to wait for the official upcoming release from pimax, or d/l the .086 and firmware updates now.
Will the upcoming release have a newer version of the PE as well. Will it finally include more assistance with IPD adjustments.
Also, I used to be able to select the darker theme on this site, it seems to have disappeared of the little hamburger menu. Is it located somewhere else now?
It was released in a weekly update, so should be “official”…
After installing PiTool 1.0.2.086 You’ll need to install PE 0.70.0.0 manually (it’s not part of the PiTool installer). And You should ignore any “update” notice for now as it’ll actually downgrade to an earlier version.
It seems the next version of PiTool is right around the corner so You could also just wait for that (maybe it includes the firmware too) as that would most likely mean You “only” needed to install PiTool (and the firmware that “follows”) and PE afterwards.
