It just says power surge on usb port when I try to connect it. hhelop
Tested the normal other usb-ports and so?
I fixed it by reseating the cable but now my pc dont notice my vove tracker dongles and I cant connect any of them because it thinks I have no more dongles
Hey Tech :
I know you’ve submitted several tickets for different issues
But if you need any technical support, please contact customer service and submit a ticket they will check that for you.
