8KX unable to connect V1 (V2?) basestations - working solution
Hi to all. I installed my new 8Kx with new Pitool …264. And problem was here. I cannot see Basestations V1 (no in Steam, no in Pitool, ther vere grey there, no tracking). With my 5K+ they are working problemless. So it was clear that the problem is in 8Kx. Why ? What i found in net in 8Kx is Bluetooth receiver and sometimes is not working (receiving) so good. So transmission basestation to PC via HMD is lost.
SOLUTION: Instalation of this
https://github.com/mann1x/pimax_bs_manager#readme
It is conecting basestations to PC through PC BT receiver. It is possible too check the status of basestations. All is working now . I think is there version for V2 BS too? I have V1 and they both are working.
Last: Congratulations to PIMAX! The Clarity a picture quality of 8Kx is amazing, FOV too, I dont see any distorsions. Use 69 mm IPD (have 64 normally) and -0,5 mm offset. I am using my reading glasses without problem, the picture is then very good.
Use 3080 EVGA GPU and it is really fast…And SDE ? I see it little bit (my glasses are magnifiging effect) but this is not the problem. Really well done 8KX (Hope my deluxe audio strap come early)
Here is thread with these programs. Glad to hear you have it working!
https://community.openmr.ai/t/how-to-power-off-basestations-remotely-solved/15205?u=heliosurge
