I have a a KDMAS I received in my backer kit for a 5k+ and I am likely to upgrade to the 8kx or 5k super.
Can I use my KDMAS on either unit?
If so can I order the HMD without a headstrap?
I dont see why the SMAS is more expensive than the KDMAS, also its not in stock…
I will only need the HMD.
I am running an AMD R7 5800X RX6800XT combo built to run MSFS2020/DCS which it does nicely.
Pimax seems to be Nvidia centric which was not known to me at the time, to the degree even the support staff told me I should upgrade to an RTX 3080 despite me telling them I just bought the RX6800XT.
I hope Pimax supports AMD to the same degree they do Nvidia. The 8KX will only do 90hz for Nvidia cards, also disappointing. Is this likely to change in the near future?
Should I only consider the 5K super instead?
That is not correct. 90hz on AMD is easy. I am still playing with (figuring out) the best settings, and each AMD update makes things better, but WOW it IS working. Project Cars 2 at 90fps native is great.
Maybe I can help you set up (with my very limited experience).
It’s a default option for the HMD, it comes with the SMAS. If you wish to get the HMD only. We suggest you to file a ticket at our support, and request it from them. But couldn’t promise this will work out.
You may some helps with @Darrell, he tried to achieve 90Hz with 6900XT.
Hi Jinathan,
really nothing special, pitool= 90hz
just worked.
latest dios, AMD drivers, pitool,
if you need.i can list them (when i get home).
beatsaber will pp no problem.
i am still working in getting project cars 2 working will.
need to lower settings to get it up to 90.
ss has a problem. seams like the recreation frame is nit in the same place as the original frame.
if drops below 90 i get this not alined issues.
so start if race (16 cars) not good. when.just one car (me) good.
It’s good enough. Have you tried reducing the FOV? My system is a bit underpowered for an 8KX, so I’ve been using Small FOV for demanding titles, like Elite Dangerous and MS Flight Simulator 2020. It’s a trade off, but I’d rather get higher graphics settings and a faster framerate.
Hopefully, I’ll be able to get a better graphics card sometime later this year.
Yes. tried all.there is a better discriptuon ob one it the other theads.
and yes good enough, for now. but there is some realy good improvens , just close.
i mean, i can see thus is a bug/ driver thing and can imagine the improvements when fixed
I’ve actually seen the “double vision” issue myself, but only when the frame rate was very low. I’m wondering if there is some sort of issue with your system. Is it possible that it’s overheating, so it’s thermal throttling?
Try running some non-VR benchmarks, to verify there’s nothing wrong with your setup. Here are 2 good ones, the first will offer helpful suggestions if something is not performing as expected. The second has a free demo version, so you don’t need to pay for it.
