When I contacted steam about the issue they did not indicate that there was any kind of fix for the units, here is a transcript of the exchange with them:
- I purchased 2 Steam index lighthouses. I just set them up and while they do seem to track ok, The status light is white instead of green. I see that this means they are in developer mode. How do I turn developer mode off?
- I cannot find the setting to turn on power saving mode. I tried SteamVR/settings but do not find that option. Where is it?
- in SteamVR/Devices there is an option for bluetooth. It says bluetooth is off. I have bluetooth turn on in the PC. The base stations also report it as off. How do i fix this?
Thank you
Message from Steam Support on Sep 23 @ 5:52pm | 1 day and 13 hours ago
Hello,
Thank you for writing in.
If the LED is white we’ll need to replace the base station.
I’m not seeing any purchases for the Index Base Stations on this account how were they purchased?
Please provide the following information:
Full Name
Address Line 1
Address Line 2 – (this field is optional and mostly used for flat, unit, or suite numbers)
City
State
Postal Code
Phone Number
Base Station Serial Number
Serial Number located on the back of the device starting with the letters FB.
Thank you for using Steam,
Alex
Message from you on Sep 23 @ 8:19pm | 1 day and 10 hours ago
Thank you Alex. I purchased both of them from Pimax (I also have their headset).
Info you requested:
(personal info deleted)
Base station 1 Serial: FB8210259F
Base Station 2 Serial: FB8230188D
Here is a copy of the receipt.
Files attached: pimax receipt.jpg
Message from Steam Support on Sep 24 @ 1:15pm | 17 hours ago
Hey James,
Since you need a device replacement and you’ve purchased through Pimax. Please contact Pimax via their customer service portal here (click).
They will initiate the replacement process for you.
If you have any further questions, please let us know - we will be happy to assist you.
Best wishes,
Nic Siq
Message from you on Sep 24 @ 4:00pm | 3 days ago
As I Said, The lighthouses seem to function properly. What are the consequences if i just use them as is? just because they are in developer mode does not seem to make them dysfunctional. Trying to get things done through Pimax has proven to be an exercise in frustration and takes a very long time.
Message from Steam Support on Sep 25 @ 11:13am | 2 days ago
You may encounter issues using your base stations. We still recommend reaching out to Pimax for further assistance as a white LED is something we would replace.
Powered by coffee,
Max
Message from you on Sep 25 @ 12:10pm | 2 days ago
I have reached out to Pimax. So, what recourse do i have if pimax proves to be unable or unwilling to resolve the issue? Can’t i just return them to you for repair? I don’t think they are broken, the developer mode must be something that all of them have, so it should be possible to get them out of developer mode. I have a lot of experience in product development so i know this is not that complicated. I would have purchased the devices from you but you never seem to have them in stock.
Message from Steam Support on Sep 25 @ 4:34pm | 2 days ago
If you run into any issues with Pimax, feel free to provide your conversation here so we can evaluate the situation further.
If you have any further questions, please let us know.
Best wishes,
Nic Siq
Message from you on Sep 26 @ 9:43am | 1 day and 21 hours ago
I read on this site:
https://developer.valvesoftware.com/wiki/SteamVR/Troubleshooting
Under the heading for Base stations:
Base Stations
Base Station LED States
White: Ready
Blue: Base station is still spinning up and waiting to stabilize. If it never changes from blue, check to make sure the base is mounted securely. Vibrations can cause it to be stuck in this state.
Slowly blinking white: Standby mode. Try unplugging and replugging the base station if it never wakes from this mode.
Solid or blinking purple: The base stations are having trouble seeing each other. Make sure nothing is in the way.
If the LED is off, it doesn’t have power – make sure that the power cord is plugged in and your outlet isn’t connected to a light switch that is turned off.
Clearly, there is some discrepancy between your troubleshooting section and this Help section. I have a White LED. Is that ok or not? Maybe i don’t need any help at all. The Light houses are V2.0. Can someone provide a definitive answer Please?
Message from Steam Support on Sep 26 @ 12:44pm | 1 day and 18 hours ago
The base stations should be green when operational.
The fact that they are remaining white leads us to believe that an issue may develop. However, Steam Support does not have any information as to what kind of issue or when.
That said, we suggest having Pimax replace your base station with a normal functioning base station.
I’m sorry as this is all the information that Steam Support has.
Mitchell
