I’m experiencing this for the first time where I get a purple led indicator and flashing green chevron but the headset still works fine as usual. What could this issue be?
I don’t have an 8KX so hesitant to reply - could it be Parralel projections option is on?
Yes, that’s usually the indicator that PP is activated.
Hi dmel642
That’s perfectly normal, and operating as it’s supposed to (you just never noticed I guess)
When PP mode is active, the Power LED will be purple and the chevron will be flashing.
(this is true for the 5K+ as well)
I hate the flashing, common sense tells you that its indicating an error of some sort.
Well, sort of correct, isn’t it - the fact that we have to waste 30% GPU performance on the stupid need for PP is fundamentally wrong…
agreed… chevron should not be flashing, the purple LED is enough in my opinion.
