Gotta remember the hz of 8k-x native is 75 though. If thats too low for you and you’re going to use the upscaler mode anyway, then why not save some money and get the 8k+ instead.
Nah I’m good with 75Hz. That’s not bad and I’m old enough to take things relatively easy, so…
But that price difference is looking good, because these headsets are very expensive, even with the discounts
Assetto is bad example to show 2x 4k native. This game in VR have resolution cap.
You can check it at you own just set Pitool 1.0 and SteamVR 120% than 150 % and 200%. You will still be able to play with the same FPS and exact SQ
Nah. How long will they deceive customers regarding upscaler?
Is Pimax recommending us to run upscaling mode with redering resolution of 1440P? Who would do that? If Pimax really intends that, they had to set SS 100% at 1440P, not something like 3800 * 2400.
Ah yes sure. My reply was a misunderstanding on my part, I thought Risa was talking about the DP spec of the 8KX being insufficient, but he was referring to the website
Robin said current cable is 5m, 10m cable does not work. But may work with a 2m extention. No details.
@sweviver can likely give a better answer with his tests.
Sweviver said no extensions he tried of any length worked for the 8kX unfortunately. But if that is the case, we’d still like to know if perhaps it will work in reduced FOV native mode (since they can turn off actual pixels now) or upscalar mode at least when we go to play room scale games vs seated.
All I know is that will determine which I get 8k+ or 8kX as I had to use a 2m extension on my 5k+ due to my room layout, couches, etc.
7,0 m did not work
6,5 m did not work
6,0 m did not work
5,5 m did not work
5,0 m
I would wait for a pimax 8k X version 2.0 . It should come out with even new lenses and 90 hz including hdmi 2.1 and a long cable . I predict february 2021. Next year in august nvidia will release the rtx 3080 ti with an hdmi 2.1 connector. I would definetly wait before ordering the pimax 8k x with just a display port 1.4.
Pimax 8K X is the Best headset of PImax 8K range
September 2020
there will be a new range with
New design rounded
New Lenses
Optimizations
Cameras
No Valve Base Stations needed
Display port 1.4 for compatibility
lol dude wut?
Just a thought…will there be a new PiTool soon which includes 8KX features eg turn upscaler on / off?
Aaaand another question. What is the weight of the 8KX both with and without MAS and CK attached? How does the weight compare to 5K+ and 8K?
So in order word, its kind of a gamble to pre-order the 8k-X??
I have a 2080TI but we just dont know if this would be sufficient to run games at a decent FrameRate…?
With all the upscale and fps throttling options in PiTool, I’m sure you can get everything running, just not at maximum potential because that’s GPU specific.
Don’t worry about it.
If Sweviver is right, rendering resolution difference between 5k+ and 8KX at SS 100% is about 8~10%.
Also 8KX has 20% lower frame rate than 5K+.
You mean refresh rate right ?
Yes, I believe that’s what they meant, and if you’re hitting the refresh rate they’re the same regardless.
unless V-Sync is disabled
