That can’t be right and I think it must be an issue with pitool (I hope so) but I need to ask
Does 8k+ should have bigger resolution than 5k+ when steamvr is set on 100%?
Colors are also the same. Absolutely no difference in graphic except 8k+ got no visible SDE.
Everything is exactly the same like my 5k+ without sde
My res at 100% in steamvr is 2562x2106
Fov - NORMAL
Render Quality - 1.0
PP - off
maxrecommendedresolution - 16384
Those of you who already have 8k+ could you please tell me what’s your resolution in steamvr at 100%? Thank you
8K+ and 5K+ has the same input signal at 5K. 8K+ upscale it but you will perceive the same resolution and have to use the same settings in SteamVR. You will notice a bit sharp than 5K+, but not a lot.
@quanentanglement that’s exactly what I had on 5k+ and now I use +2 red and green +1 blue -2 brightness. I can barely see any difference. Also I had sharper image on my 5k+
@Culver9
Not sure then. Maybe down to settings? But my 8k+ is much much better then my 5k+ in colors, contrast , resolution screen door effect, comfort, I can push res higher and get better performance than my 5k+. What is your GPU?
@Culver9
I’ve tested a lot of games.
Boneworks
Siners and saints
Shadow legend
Curios tale of the pets
Hellblade vr
Fallout 4
Skyrim
Luckys tale
Probably some more, Lucky’s tale looks insanely sharp and smooth! No horrible black dots like my 5k+.
I was seeing details in Hellblade that I never seen before, and that game is heavy workload for any GPU.( should still have headroom to s.s. with next gen.)
Fallout 4 actually looks awesome. I think I may finely play this game. Going to add some mods and figure out controller scheme. Index controllers aren’t compatible I will probably use OG vive wands.
How would you be able to push res higher and get better performance? The work being done by the GPU is exactly the same.
I am sure the 8K+ is great but this sounds a lot like placebo effect (for the performance).
