8k+ 268 beta is worse than before for me. In the previous one I could see 2 little white lights at the edges but now I can see a big bar almost in the center of the left screen (all of this with 110hz, 90hz work well as always) @Heliosurge @PimaxQuorra @Alex.liu
its working for me, but still lights at the edges.
maybe flash fw again
added Alex to your post.
thanks 2020202020202020
Hi beatet:
Can you take the photos about issue?
is there any different between the FW 268 and last version when the headset running on 110HZ ?
With the previous version there were two little lights on the edges of the screens. With this one I can see these lights less but you have to add the big bar in the right side of the left screen (I think I write a mistake in the previous message,the problem is on the right side of the left lense)
Hi Alex, i just tried the new firmware and your new pitool. my 8k+ display is more dim and the colors are brownish, is this supposted to be? Iām reverting back to Pitool .262 and firmware .264,the brightness and vibrance of colors are much better for me.
use fw 268 , fix the brightness
oh thanks i will try later, i assumed the new firmware was bundeled with the new pitool
i can`t see what happend about your headset from photo , please make a ticket to doman , export the log of panel to help me solve the issue.
thanks .
