Will the 5K/8K models support 60 Hz refresh rate (or some multiple of 60 Hz)?
When watching 60 fps movies you get less judder if the refresh rate is 60 Hz. I rarely see this problem mentioned, but it’s something I really care about. I have an Oculus Rift and a Gear VR and the latter definitely plays 60 fps movies smoother than the Oculus, because the Oculus is fixed at 90 Hz (which forces it to e.g. show odd frames for 11.1 ms and even frames for 22.2 ms, instead of showing all frames for 16.7 ms).
I know Pimax 4K supports 60 Hz, and I will get one if 5K/8K won’t support 60 Hz, but I’d rather wait for 5K/8K otherwise. (I also read that the 4K model will get updated hardware very soon. I hope that doesn’t mean it won’t be able to use 60 Hz anymore!?)
Added xunshu. It was requested due to Optimus laptops that pass through intel igpu. I can’t see why not as it will help those users & provided Brain Warp works well could give those users a perceived 120.
Few ways to add positional tracking including possible valve tracking.
As he mentioned thogh it has to do with Movie watching he said he found on Rift jitter in playback of 60fps. Where the GearVR does a better job being 60hz.
I really do want 60 Hz, yes. And you don’t really need positional tracking for watching movies. Also, I’m actually a bit skeptical about the 200 degrees FOV. Maybe it’s me, but my Rift looks worse the further from the center I look, and my Gear VR even more so. I think I’d rather have perfect looking 90 degrees than 200 degrees with lots of blur and artifacts, if I had those two options. (But I’m not sure.)
All VR headsets seem to have their problems, and some people experience problems that other don’t, with certain headsets. And given the rather extreme specs of the Pimax 8K, I’m afraid it might have more problems than other headsets. I hope they prove me wrong, though!
I think with 200 degrees FOV if you see some thing out the corner of your eye even if not in focus you will turn your head to see what it is, but with current HMDs you cant see it, you have to turn your head first to see if anything is there.
No idea. I posted a request for 60 Hz vs 64 Hz quite a while ago (when this was first announced as an upcoming feature. It doesn’t make any sense at all to have a 64 Hz refresh rate. 60 Hz is good for most videos (90 Hz is also good, if you have a 5K+, not an 8K, which maxes out at 80 Hz).
Do not understand this topic.
What has the frame rate to headset doing with if the video is recorded in 60 Hz.
This will be upscaled by the graphic card.
I’m not sure what part you don’t understand, so I’ll break it down. (This intended to be thorough, not condescending.)
Upscaled means “stretched” and that’s not the issue. The issue is that movies and videos are recorded at a specific number of frames (still images) per second. If there is a mismatch between the recording rate and the playback rate, some of those images won’t be displayed for the same length of time. That results in motion artifacts, which bother some people.
It’s OK, if the frames are repeated, as long as each is displayed for the same length of time. Movies are typically filmed at 24 fps and can be nicely displayed at 72 Hz, since 3*24 = 72. In the case of video, typically recorded at 30 fps, playing it back at 64 Hz means the 4 of the frames will be displayed for 50% longer than the others. This can appear as visual “hitching”, where smooth motion appears jerky.
Hello ,
“upscaled was a wrong word from me”
If I play material recorded in 60Hz ,the framrate to the headset is close to 90Hz.
What is it that decide the framerate to the headset ?
