Can the port on the HMD be used as a hub?
I have an Audeze headset I’d like to use this way (instead of through BT or seperate USB)
It is just a usb2 port. So yes you can use usb devices on it. Just keep in mind the usb-c is not a usb3 port on the 5k+ as it was supposed to be as per KS.
They didn’r implement usb3 until the 8kX and refreshes on 8k+ and Artisan. 5kSuper also has the usb3 as it uses the new mainboard.
Some have even had to use the hmd usb port for a watchmen dongle as some units seem to have a defective watchman in the headset.
