Built a small adapter for the leap motion module.Works like a charm. Cant wait for the Pimax module.
Awesome congrats!
@anon74848233 please add to earlybackers
The power of hot glue. :9
Any LM applications you can recommend, for when we get our Pimax OEM units? :7
A global virtual keyboard would be ace! …I recall there was a SteamVR controller simulator…
Hi there . How big is the range of your hands with the leap motion? Can you somehow see your hands for the full 5k+ field of view ?
I can see my hands only on part of the 8k field of view
Yes that’s to be expected.
From the Leap motion FAQ : The leap motion Controller’s field of view (FOV) is 150 degrees wide and 120 degrees deep (averaging 135 degrees)
Tx for the reply. Do you know if there is a way to use vive controllers or vive trackers as tracking methods for tracking hands and harms and some other sort of finger tracking across the whole fov ?
