I just got my 5k+ today in the UK but PiTool just doesn’t detect anything. Not the headset, not the base stations and not the controllers.
Headset has power and the front LED strip is alive. The power LED is currently red but was green earlier. It makes no difference though.
Here is what I did:
Installed PITool (.90)
Connected USB cable to PC
Connected DP cable to my AMD card
Connected AC cable to the dongle
HMD turns on and Windows 10 adds Pimax as Bluetooth device
PiTool detects nothing and says I should plugin the HDMI/DP cable
Weird symptom: When it is plugged in, there is mouse lag that occurs at 1 second intervals.
I’ve tried (1) uninstalled and re-installing PiTool (2) different orders of plugging in (3) different USB ports and versions (4) powering on and off via HMD button and via AC (5) firmly pushing the cable that goes into the HMD in case it’s loose.
Go to the ‘services’ tab in your task manager. Locate PiStarterService. Right mouse click on it: Stop it. Wait 10 sec. Start it. If not, do it again. Should work after 1-3 times.
Sorry, just to ask again… does it make sense for gfx card issue to also cause the base stations and controllers not to be identified PiTool? Nothing is being detected apart from USB.
Hopefully it’s just a case of detection order - checks for USB, then checks for HDMI/DP and then moves on to base stations and controllers. That’s what I’m hoping because otherwise my HMD is probably broken.
Please can anyone with a 5k or 8k please unplug your video cable and tell me if that then causes the base stations and controllers to no longer show as detect in PITool?
Any luck resolving this issue? I just got my Pimax 5k+ and I’m having the exact same problem. HMD turns on with solid red light and pitool says the HDMI/DP is disconnected. I have an Nvidia GTX 1080 with the latest drivers so it isn’t something to do with AMD graphics drivers on my end. Unlike you though I never had a green LED if that matters at all.
