Every once in awhile when i go to use the 5k plus, i have this weird bar in the middle of the view.
The only fix is to reset the goggles via the power button.
Has anyone else ran into this?
Thanks
Thanks
Yes. Like you said, I just reboot the headset and it goes away.
Thanks for confirming its not just my headset then… must be a generic glitch.
Does anyone know if they plan on addressing this issue? IE: Is it a software glitch they can later fix…
