That should work. Display Port versions are supposed to be backwards compatible. Is there an option in PiTools to let you reduce refresh rate to 75 Hz? I have a 980Ti with the same DP limitation. I sure hope there isn’t a problem which prevents me from using my headset (in a few months, when it arrives).
That is most unfortunate. Several people have 980Tis, like me. It’s roughly the equivalent of a 1070, so I (like others) assumed it would work with the headset.
I don’t see how DP 1.2 will support the Pimax. The specs are too low to meet resolution/refresh/bandwidth demand. This isn’t just a question of if a card is fast enough, its not able to meet what the Pimax is requiring as input signal.
17.28Gbit/s vs 32.4Gb/s bandwidth.
As far as I can tell 2560x1440x2@90hz requires higher than 17.28Gb/s
True, but if the refresh rate is lowered, it should be able to work. Pimax has indicated that they might support 60 and 72 Hz refresh rates. That should enable DP 1.2 to work, since 75 Hz and lower should fit the available bandwidth.
Yea, those features are not in yet but maybe possible? Don’t know enough about how they communicate but at reduced refresh it should be within bandwidth capability.
sounds like a per case grey area then… unsure if reduced fov reduces bandwith still or if its sort of fake reduction and only reduces rendering res? no idea if other factors still come into play to approve accepting the signal?
I did more playing last night, attempted to use my phone as poor mans lux meter and compare when connecting via different usb ports but readings are quite low so wasn’t getting anything useful.
Also noticed a brightness slider in bigscreen, put that on max and and have to say I’m still feeling it seems a bit better than I’ve seen during the past few days.
I’ve just gone into steamvr home now and I am absolutely certain now it is brighter than it used to be! no idea why yet? .90 or my pc?
Either way the main thing I was still disappointed with colour/brightness… I’m less disappointed with today
Quite possibly, even the small amount of visible SDE is starting to disappear for me at the moment. Clearly getting PiEyes
I did a rollback to .84 and brightness looked the same, but pixel quality wasn’t as nice (and I did check all settings pitool/steamvr), went back to .90 and all nice and clear.
