Updated to 1.0.1.272, the device power LED is now always blinking red/green/blue. PiTool does not recognize the device as being plugged in. Also did the steps to manually put the device into dfu mode. Tried to manually flash with the dfu tool and it cannot with error:
0 Device(s) found. Plug your DFU Device !
Target 00: Error Code: Unknown error 0x12340005.
Target: 00
TransferSize: 0
DFU State: STATE_IDLE
DFU Status: STATUS_OK
Request: (unknown 0x8C000000).
CurrentNBlock: 0x9975B611
CurrentLength: 0x766B14
Percent: 0
If I unplug and plug in the USB I can hear the disconnect/connect sound, but nothing is recognizing the device as being plugged in anymore so I cannot flash the firmware. Is there more I can try or was this bricked by the update?
