There is some threads out there already but they are all kinda messy imo, at least the ones i’ve found.
These are the cables i’m using and they work very well BUT the USB cable need to be connected to the vive box in order to get enough power (i tried a usb hub 3.1 but didn’t work well at all).
BTW everyone who has extension cables that works please post them so we can have a big united thread of cables working for 5k+. Makes it easier for everyone
I can confirm both USB and dp cable ext are working for me but they make my desire for wireless module even stronger. I want to add the power cable which is working for me but no warranty, as it depends on yr power supplier, too. The following has AWG 20 I. E. I think 25 strands of copper which should be sufficient: DC Verlängerungskabel 3,5mm x 1,35mm - 5m - schwarz https://www.amazon.de/dp/B012TX7W88/ref=cm_sw_r_cp_taa_pM-WCb6TPE2TF
Can’t recommend any but don’t think you have to be super picky when it’s down to those lenghts I used one 1 meter usb cable and it worked but maybe was lucky
