Hey everyone, sorry if this has been brought up, but I can’t find it. I have installed Piplay on 2 different computers in case that made any difference. If I go to the device tab there is no box to check to force 25601440 mode. The only box I can check is for 19201080. Does this mean the default is 25601440 or am I just missing something? I have also enabled the beta versions just to see if that made any difference and it doesn’t seem to. The reason I am curious about all this is because everyone i have researched talking about this says there is no screen door effect on the PiMax. While it may be a bit better than on the Rift there are definitely visible pixels on mine. I wanted to see if I can force 25601440 in case that fixes the problem.
Also does the firmware auto update with Piplay? Otherwise where do I update it?
Any advice would be awesome. Thanks.
