Pimax Headsets can use either LHes. However LH v1 cannot be used with LH v2.
So you would say have to use a single LH for seated games. & use the 2 that match version for Roomscale.
In PiTool .111 I suggest you go to the menu where you turn off the lighthouses and temporarily uncheck that box and see if it tracks at all. Test it then check the LH box again and test it again. This causes the LH routine to reset.
Ah OK, I think I misunderstood this image
From here:
https://steamcommunity.com/games/steamvrtracking/announcements/detail/1264796421606498053
its already answered by the specs of the 5k+/8k if it runs with LH 2.0 then it must be TS4231 or newer
Strong Compatibility - PiPlay / Steam VR/ Oculus. Mass mainstream VR contents are prepared for you. It also can support for Steam 1.0 and 2.0 Lighthouse.
1.0 and 2.0 bases are not compatible because the way the ir beam is synced (intermittent beam from bases) is different the old 1.0 uses a array of ir led’s (the green board in the picture of the 1.0 unit) that is not present in the 2.0 units sold (the “sync on beam” in the picture is the hint)
Ah yes sorry makes total sense. Was a long day yesterday
