I have the option of buying two vive controllers and 1 base at a good price, because I can´t wait anymore with the 3dof pimax.
Do you think i will have any problem configurating the space or something?
why should there be problems??? The Vive controllers are compatible!
i use 2 controllers and one LH and its fine atm.
Would be best with 2 base station but you can buy one later on
Compra los te vendrán bien, sera mejor que 3dof
I bought one base station to use with my 8k and iRacing a few weeks back and it will not track. Tried all the suggestions in the forums but nothing.
Been waiting a week for a reply from support.
You should be good for standing games. They demoed this back in the LA backer meetup prior to headset release.
@SweViver likely has good info on setup & possibly a video on it.
If you know someone with a vive; I would recommend testing it as some hsve bought duds.
Nowadays (with all later PiTool versions) you can run with 1 basestation and 2 controllers without any problem. Nothing needs to be changed to get it running and u do the room setup in SteamVR just as normally. The head tracking is basically 360 degrees and works urprisingly well. The controller tracking works good as long as u dont cover them with your body of course.
For sitting down games and sims, 1 basestation is more than enough.
Im running 1 used base station and no controllers, except for xbox and a HOTAS, with no issues…great tracking.
Yes just remember to have your hands in sight of the one basestation at all times. Headset should be good 360 but you hands will need to always be seen by the one lighthouse
in general that should work, pimax demonstrated room scale vr last year with one LH (was surprisingly good, YouTube) and 2 controller will make every vr game usable
my guess is most unpleasant things will be occlusion of controllers with your body when doing room scale vr, but cant be worse than PSVR
Thanks for all the answers
Have you set it to “a” mode (using the button on the back)?
I have and it made no difference. Getting tracking initialized is a pain in the butt. After it’s initialized, it works great from then on.
Hi Dave,
Yes, tried that, along with all others suggestions here on the forum.
I have been using the 8k without any basestations for a while on iRacing, love the field if view, makes racing on tracks with walls so much easier to get close to them for the best driving line.
I get some very random freezes, mainly when i am looking into the apex of a corner, i naturally lean in and wondered if a basestation may help this. The picture freezes on my view with head turned, so if i move my head during the freeze my point of view is off at an angle and usually results in a crash due to disorientation. I have mapped a reset view on my wheel and if i am quick enough can sometimes manage to save the situation.
I bought the vive basestation via Amazon Prime, not sure if i still may have a dodgy unit. I do not know anyone with a vive set up locally and only get 3 or 4 hours per week to spend resolving this, at the expense of racing.
Hopefully there is still some help to be had before returning the unit.
There is a way to check on lighthouse log file. @TheIronWolf used this to find out he had a bad LH.
Hi,
Thank you for the suggestion.
I have looked at the vrserver.txt file and cannot see any lighthouse axis failure messages.
Yep, see here: https://community.openmr.ai/t/v1-valve-lighthouses-identification-and-diagnostic/16330
v1 and v2 lighthouses are simultaneously compatible with Pimax headsets, correct?
ie I now have a single v1 lighthouse for when the 5k+ arrives. Currently on WMR so it doesn’t have a use yet.
I have ordered Pimax v2 lighthouses and controllers as well.
So my Pimax plan is to play seated games with the v1 lighthouse (Elite is always my top priority hehe), and then when the v2 stuff arrives, I can theoretically use all three lighthouses for room scale, as the Pimax headsets are new enough to support v1 and v2 at the same time?
If I’ve misunderstood, then I can just sell the v1.
