Attention: This Piplay version needs to use the latest Firmware(1.0.0.194), and then you can use the newest functions. If your Firmware is lower than 194, you can’t connect you Pimax with your PC. So please update your firmware when you see the firmware update window.
Piplay updating instruction:
1, Newest Pimax mode, compatible with the Steam VR platform’s game.
2, Mode switching optimization, optimize the user experience.
3, New setting mode (top right corner), including the IPD setting, color setting, languages switching, boot automatic selection, location setting and some new functions.
4, Game categorization, you can easy to switch your mode between Pimax mode, extend mode and direct mode.
Detailed instructions:
Instructions of compatibility
Extend mode: Extend mode is compatible with OC 0.4, 0.5, 0.6 games, support LiveViewRift, Maxvr player(Some games do not support Windows 10).
Direct mode: Direct mode is compatible with OC 0.7, 0.8 games.
Pimax mode: Pimax mode is compatible with Steam, OChome platform. We suggest to use the Simple VR Video Player (Steam platform).
PC supposition instruction:
Piplay will opens the modes if your PC fulfills the condition:
Having integrated graphic and can not close it (laptop): Only supports Extend mode
Without integrated graphic, only has NVIDIA graphic, drive version is between 358.70-362.00: Supports Extend mode, Direct mode and Pimax mode.
Without integrated graphic, only has NVIDIA graphic, drive version is over 362.00: Supports Pimax mode and Extend mode.
Without integrated graphic, only has AMD graphic, latest drive: Supports Extend mode, Direct mode and Pimax mode.
Updating FAQ
Piplay updating instructions:
Auto-update. When you open Piplay, it will check by itself if it needs to update. If you haven’t update it for a long time, please open Piplay as administrator, it will check and update by itself.
FW updating instructions:
FW updating needs 2-3 minutes. If you take a long time such as more then 5 minutes, you can do it like this:
Reason: Some system’s user need to install the latest USB drive (STMMicroelectronices DFU Device driver)
Solution: Please download and install the STMMicroelectronices DFU Device driver and Microsoft run-time and try again.
