Hi @PimaxVR,
Have you tried reaching out to SteamVR to see if they are willing to support higher resolutions (up to 4k x2, and beyond)? The VivePro at CES now sports a higher resolution, so SteamVR also supports this resolution. Though there will still be some scaling up, because the current standard of DP can’t push 4k x 2 @90 hz, SteamVR should support the highest resolution available so that when next-gen headsets, like Pimax 8k and 8kx, hit the markets they will already have supported resolutions.
SteamVR should also require future VR software support dynamic resolutions, and strongly recommend existing VR software update to dynamic resolutions.
And I know this last part is out of scope of this post, but if the opportunity arises, could you also ask them to integrate Piplay into SteamVR so that users don’t have to install/start extra software to get going?
