Being keen to use the most powerful consumer GPU, my question is will the 8K Pimax support the upcoming Nvidia USB Type-C and VirtualLink as present on the RTX2080ti?
Unlikely, they’ve supposedly started manufacturing headsets and the ones seen so far use straight Displayport cables. 2080ti does have normal displayport too so it isnt an issue.
all the new port does is save cables, there’s no more functional value to it than that.
Just need a breakout adapter plugged into each end to use single cable for the 8KX
