what do we need to get the samsung odyssey plus working with the vive controllers?
Do we need the vive headset also or can we do it with the lighthouses only?
Or can we use vive usb dongles?
And does it work perfect?
Probably need dongles & i believe you have to edit a config file to use wands without a headset.
@crony is one a likely a few who would likely know steps.
I became aware of this the other day, really interesting… and you were part of that discussion? @rothman gave you a few links to all info!? https://community.openmr.ai/t/mrtv-preliminary-samsung-odyssey-review-including-pimax-comparison-pics/10461/146?u=spamenigma
So as a reminder you either need to use a VIVE headset as the receiver. ‘or’ use 2 USB dongles that come with VIVE pucks which are obviously not as common for people to have so as an alternative you can use 2 vive controller dongles and change the firmware.
Dongles available here: Welcome to Steam
so if we get the usb dongles from the link you give @spamenigma and flash the firmware(wich firmware and how by the way?)
And edit some config files,and then it all works 100% even if we do room scale ingame?
The flashing of firmware is mentioned in the first link he gave:
I checked the location and firmware is there for me.
