When we look at the Valve Index controllers we’re so lucky to see that the Pimax controllers has ZERO know defaults up to now!
A common problem with those type of buttons, to some point I had it with my PS3 controller and my XBOX, definitively have it with this one. Answer by Valve is correct by design those types of buttons are constructed to support a strait directional upward /downward pressure to activate the contact. when the cursor is tilted pressure on the contact become more and more difficult with the tangent angle increasing.
Not 100% in accord with you when done correctly you can infer SDE so definition is also possible to infer. Oled panels are distinctinguable from others. I can appreciate in these images the qualities I see in my 5k+ it’s not % perfect but it’s better then nothing. From experience only swiviver and tyriel give acceptable and comparable results over time… and those captures must be interpreted with comments from the reviewers. When we add all reviews the Sum of the all is better then the individual reviews.
For colours nothing can be ok unless you have calibrated equipments from capture through visualization
yeah i saw this. Wouldnt it be funny if Pimax swords turned out to actually be “better” than the index lol. I mean every review ive seen so far talks about how the actual button layout is so much better on the touch. And that the grip button is missed.
And now you can add this joystick issue into the mix.
pimax controllers have been shown to be more ergonomic, mimic the touch layout exactly and if the joysticks actually work like joysticks. Pimax could actually do it!
This would be awesome indeed. Noticed Index controllers don’t have shoulder button only trigger & imagine the trigger is only single stage unlike the steam controller.
I really hope the Pimax “Swords” are good. Im just tired of using the Vive wands and ready for something better. I really didnt want to drop another $300 for Index wands then find out the Pimaxes are better
