Ryleth
November 21, 2020, 10:44pm
21
soo,you fixed it?my p4k gave me that red/green led a few times,used the dfu.exe that comes with pitool and its working again
if your 4k is firmware .265 then downgrade it with 1.0.0.248_anti_TakeApart.dfu and wait for pitool to detect it again,
if its working again then use the dfu.exe from pitools again to upgrade back to .265
found the firmwares here : https://keybase.pub/playa/Pimax/Firmware/4k%20Series%20(P1)/
QWEXZZ
November 22, 2020, 11:09am
22
Программы для прошивки не видят шлем.
Ryleth
November 22, 2020, 6:47pm
23
connect the usb,does it light up or something?
QWEXZZ
November 22, 2020, 7:23pm
24
горят 3 светодиода: красный, синий, зелёный. в независимости подключён hdmi или нет.
отображается в подключённых устройствах как pimax p2a. pimax и pitool не видят подключения. Но в pitool меняется номер ошибки с 20000 на 20400.
Ryleth
November 22, 2020, 7:52pm
25
you dont need to start pitool to flash the firmware,just connect the usb and start the dfu.exe on the runtime folder “C:\Program Files\Pimax\Runtime”
you need to have the firmware for the p1 already downloaded
Ryleth
November 22, 2020, 8:07pm
26
i can help you via teamviewer if you need,just send me a message
system
Closed
January 22, 2021, 7:16pm
29
