after a year of using PiMAX4k, the upper belt clip (over the head) broke.
to Pimax4k always treated carefully.
I noticed that this upper belt clip is very thin.
This weak spot is Pimax 4k ???
And how do I use glasses now?
I used superglue, but I’m not sure if it’s for a long time ((
I’m sad (
JbWeld is an excellent epoxy that works well & can be used to reinforce that area. A new product Qbond I think its called is a wonder product as well. But truthfully I think jbweld will do the trick nicely.
Thanks again George I have this exact problem on and expensive pair of Siberia 800 wireless headset where the lower brackets broke and I tried using superglue one side is holding but the other has come loose so I ordered your suggested product of Amazon Prime for 11.75us total. I guess it stays somewhat rubbery not sure though. @Heliosurge is always good to for a helpful suggestion to readers on various problems appreciate that guy as well.
