Can the new standard MAS be altered later to the deluxe model with parts, or would a new purchase be required?
I want to go ahead and order the 8KX now that I have a refund coupon I was waiting on ( before it stops working) but as many I’m stuck on the MAS decision!
Also does rejecting the tracking discount only get you $50 off the 8KX upgrade, but keeping it gets you $100 off the eye tracker?
Hmmmm. Not sure you understood my question? The discount is less for the 8KX upgrade than if you keep it for eyetracking. I don’t understand you response?
Still confusing. 1 eye tracking was supposed to be free. so the $100 discount should apply to 1 eye.
Anyway, my main question is about the MAS. Any ideas?
Yes it bit confusing. Essentially if you keep Eyetracking it is Valued as $100 off: as a credit it is $50 towards a headset.
The MAS Standard question is a good one; can the Standard MAS later be upgraded to deluxe via buying the deluxe headphones without buying a new headstrap.
That’s great news! I’m going to go standard and save the $100. If the standard is not acceptable. I’ll upgrade later. Heck, if the deluxe Mas is still not ready when the 8KX is shipped, that could even result in a additional delay. Yep, standard it is!
