Some peripheral objects "Pop in Pop out" when moving HMD
Hi,
I noticed this problem during my first visit to the SteamVR Home environment. In my peripheral view I can see objects appear and disappear depending on the position of my head and yes even on small FOV.
The same thing happens when working in Unity. When I start the build some objects pop in / pop out all the time.
I think there is a correlation with the total number of objects in a scene and how many objects pop in/out.
Clearly a software problem.
Does anyone have a solution for Unity? a setting to tweak ?
Thank you very much!
Edit: also read about frustum culling
You must enable hidden mask and / or parallel projection in Pitool.
I believe you enable Parallel Projection in Pitool. I have this anomaly too. But I havnt yet tried to enable PP. I deal with it rather than losing FPS by using PP
