Skype support has been offline since 27/02
I need to contact you, my headset with every firmware update is unusable and the repair tool is the only thing that makes it work again, thank you
Hi, please contact me through Skype if you’re available now.
Can you come to piplay beta & guve us updatevon why your team is still not fixed the 2k setting?
Your custom resolution is causing headset to be unusuable with the visual degrade & distorted visuals. Due to not using 16:9 resolutions.
We’re still not receiving information on what is being tested in the betas.
Please help & fix 2k to be 2k
When are you online? I have a week trying to match your schedule (10:00 - 22:00 UTC+8) and there is no way, every time I check skype there is nobody online
http://community.openmr.ai/t/skype-support-has-been-offline-since-27-02/1334/4?u=virtualreality
Hi, what’s your name of Skype? I will add it, tks.
