I’m currently using my Vive either seated in front of the PC where I have a single basestation mounted or standing (room scale) in an adjacent room (I’m using 5m HDMI + USB extension cables), where I have two basestations mounted.
This setup was set up by just performing the SteamVR room setup twice (once as seated and once as standing/room scale) and wherever I want to play I just power on either the single basestation (channel A) or the pair (channel B +C) and it just works.
Seeing that with the Pimax 5K+/8K You need to use their own room setup (but also SteamVR’s too as far as I understand?) in PiTool, I’m wondering if this will work the same or if I have to redo the room setup every time I switch between standing or seated gaming?
