Screen will not turn on / Black Screen
Hello, I bought my Pimax 4K VR last December and it had worked great just until a few months ago (I just decided to start fixing it now).
Basically the screen will not turn on.
I have installed many versions of PiPlay, flashed the correct firmware to the device (100 serial #), tried multiple computers and it still does not work.
The device IS detected, sound DOES work, and tracking also WORKS. It’s just the display is black.
I have not dropped the device or misused it.
MY GUESSES TO A SOLUTION:
  • Could the infrared sensor be broken / damaged?
  • Could the internal wiring have become lose on the display causing no connection?
@Pimax-Support @bacon
Does the blue LED lights on?
Perhaps you need to hard reset your HMD
Let’s check the resolution in pimax_setting, try 1980x1080.
Yes, blue LED light is on at the top.
Yes, Resolution is 1920x1080
So it seems, there is a hardware problem.
You can try to open the HMD by using a mini screw driver (cross) and open the screws on the sides who are coveres with closure stoppers. Or you go to a specialist to ask for.
I might have to open it myself, if the official Pimax Support doesn’t help much then it looks like I’ll do that. I’ll let you know my findings as soon as I can.
RIP Pimax, just blinking Red and Green. Tried to flash a hacked firmware too and still nothing.
Let me see if I can help. I assume you flashed my hacked FW ? Did it flash succesfully ?
The flashing Red&Green makes me think the flash failed and that you’re not on my hacked FW just yet.
I downloaded the firmware flasher tool as well and used that, it says it was successful but still nothing :frowning:
If you restart the flashter tool, what FW version does it say you’re on ?
I often have that black screen issue. Than I always remove the USB cable, plug it back in, restart SteamVR and most times it works then.
@LemkeGaming
Hi, usually we do not recommend users to disassemble the headsets, which may break the warranty.
Anyway, please send ID & Password of Teamviewer to support@pimaxvr.com, I would like to assist you remotely when you’re available.
i had a black screen with the latest piplay and unchecked the 1920x1080 setting…
also disabled dsr settings in nvidia control panel
made sure resolution in nvidia control panel was 2540x1440…
